RECKLESS 2000 GMC RCSB Build - LS1TECH - Camaro and Firebird Forum Discussion
Notices
Staff Vehicles Showcase Check out the rides that belong to the LS1TECH Staff.
Old 01-29-2019, 10:46 AM
Super Moderator
Reckless's Avatar
Default RECKLESS 2000 GMC RCSB Build
Bought this gem in Feb 2017. One owner truck with 166k and nice options for a regular cab. SLE Model with 5.3L, 4-Wheel discs, 3.42 posi rear, and spray in liner. I drove the truck daily for about 10 months with no issues.
Reckless is offline
Old 01-29-2019, 10:47 AM
Super Moderator
Reckless's Avatar
Had the chance to pick up am ERL 416 (LS3 based) short block as they were going out of business. Paired that with GMPP LS3 heads, BTR springs, and a Vengeance Racing “KAOTIK” camshaft. Got a used LS3 intake and added a NW 92mm throttle body and Holley fuel rails. Also upgraded to a 450 pump in the tank and Aeromotive FPR on the firewall. Relocated the coils for the Vengeance valve covers. Headers are TSP 1 7/8”. Decided this would be the best time to also convert to an RPM Stage IV 4l80E and FTI Triple Disc converter (planning ahead).
Reckless is offline
Super Moderator
Reckless's Avatar
After a few weeks I added a used Tahoe center console and fabbed everything up for a B&M shifter. Added a couple gauges as well. I did remove the column shift lever eventually. I drove the truck most every day for another 8-10 months.
Reckless is offline
Old 01-29-2019, 10:48 AM
Super Moderator
Reckless's Avatar
I then decided it needed a better stance, so I purchased the full Ridetech system with ride height sensors, 5-gallon tank, dual compressors, and wishbone rear. I want to eventually convert this to a 4-link and use the Shockwaves instead of coil-overs in the rear. We removed one of the rear cross-members in the back and mounted everything at the rear of the frame. This leaves room for the Radium triple pump fuel cell I have waiting to be installed next. Had to add wheels for the right look, so I got repro GM Wheels in natural finish 22 x 9 with Nitto rubber (275 all around). To finish off the look, I bought new front bumper pieces, grill, headlights, LED turns, rear roll pan, etc. Had everything painted gloss black to murder it out a bit.
Reckless is offline
Super Moderator
Reckless's Avatar
Stock brakes were not to my liking at all. Too many times when I puckered up when someone slammed their brakes in front of me. Went for the Wilwood Aero 6-piston setup in front and the Aero 4-pistons in the rear. At the same time we did the hydroboost conversion using the write-up on this site. I sourced all new parts for this, and replaced the steering rack and PS pump at the same time, so everything would be fresh.
Reckless is offline
Old 01-29-2019, 10:49 AM
Super Moderator
Reckless's Avatar
A few weeks later I had paint correction done on the 18 year old paint. Still plenty of rock chips, but it looks way better!
Reckless is offline
Super Moderator
Reckless's Avatar
Next on the horizon:
- Install the Radium fuel cell and plumb -10an to the front with a -8an return
- A stout 427cid engine for boost
- Narrowed 9-inch and 4-link the rear and stuff some huge tires back there
- Some manner of forced induction
It's all just a matter of time and money!
Cheers!
Reckless is offline
Old 01-29-2019, 11:42 AM
Man, you fixed that truck up fast and with the right parts.
I need to learn how to do "paint corrections" too. That's looks amazing!
383z is offline
Old 01-29-2019, 07:03 PM
Kingc8r's Avatar
Awesome build, I wish I could find a RCSB that clean around my way but no luck yet.
Kingc8r is offline
Old 02-05-2019, 02:32 PM
mjs1012's Avatar
Awesome build. That this has gotta be fun to drive. It's lowered too much for my liking, but other than that it's a good looking truck. I'd love to find a clean rcsb and do a build one day but living in the north east it's almost impossible to find one that's not rotting away.
mjs1012 is offline
About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
