Lowbeam Bulb Swap
Lowbeam Bulb Swap
Hey, guys.
Can someone please tell me how to swap bulbs for the driver's side lowbeam headlight (98-02 TA)?
Recently noticed that it's out when stopped in back of another vehicle with polished paint. The passenger side lowbeam works, as well as both highbeams.
By the way, is the correct bulb available at Autozone?
Thank you.
Thank you.
Yup. Replace in pairs. You need a phillips screwdriver and a t-15 torx screwdriver. Isnt hard at all.
Put the light up manually with the ****, and its pretty self explanitory
Copy & Paste Moderator
1. Turn headlight **** all the way to the on position.
2. Turn headlight **** back to middle position
headlights will stay up but be off
3. Using a philips screw driver, remove the three screws from the plastic shroud surrounding the headlight bulbs.
(left, top-middle, right)
4. Pull off the plastic shroud
5. Looking at the thin metal trim around headlight bulb, use a T-15 torx to loosen the top two bolts half way (the bolts are about 1in long).
6. While holding the bulb, remove the lower two bolts.
7. While holding the bulb, Tilt out the metal trim ring.
8. Pull out the bulb.
9. Pull the connector off the bulb.
Reverse the process with the new bulbs.
I have not had time to get someone to install them yet but any info would be great if you can help, also would hid bulbs be ok in these units, the new units also came with wireing harness's, thanks colin.
Originally Posted by firebatbirdv8
I thought these headlights were sealed beam units ( can't take bulbs out )
i have now got myself some new high & low units, here is the link: http://www.rallylights.com/detail.aspx?ID=3929
Wrong. Go look again.
