DIY Pass Window Fix Step by Step (PICS missing)
#82
Alright so i broke the old regulator as i was taking it out so i ordered a new regulator with motor. Installed it in and now the window has problems going all the way up i have to assist it. It is not the motor because sometimes i get around 1 1/2 inches way from the window being all the way up and after the motor is stoped it slowly creeps up a half an inch or so. Then i have to stick a screw driver under the window(door panel is still off) and pry it up. Any ideas
#91
Ungrounded Moderator
The OP is still active on this forum so maybe you could PM him. The pictures could be added as attachments or we can set up a place to host them if necessary.
For the most part, the instructions are very complete and can be used to complete the mod even without photos.
#97
No luck finding pics after digging through multiple backups of my old system.
However, I did a quick google search and found this link on another site that has a diagram of how to wire the passenger window but I think the driver side was wired slightly different and has different wire colors as I remember.
http://6litereaterdesigns.com/forum/...hp?topic=710.0
