Alpine type x 10'
Alpine type x 10'
I was wondering if this sub can fit in kee's or any one else stealth enclosure?
im sure the type r and the type x or way different
(thinking of upgrading from a type r to a type x.)
The Type R is 6-7/8in top mount depth, The Type X is 8.6in top mount depth... Its jus shy of 2in taller then the Type R. How much room is there bewteen the bottom of the magnet on your Type R in your stealth enclosure and then ask yourself if you have about 2in to spare.
i believe i have seen some stealth boxes with a mounting depth of 9 inches, but you would use up all of these airspace inside the box. a better idea would be to have one built for your passanger side since you can get significantly more airspace.
i think kee should read this and answer my question!
Hi! You should be able to get a 10" Type-X in one of the fiberglass enclosures. It will be close but I am sure it would fit, especially if I did a 3/4" mounting ring on the surface. That's one big sub though...motor structure wise.
I have 4 fiberglass backings fabricated ready for completion.
