? -- problems with Turn Signals
Old 12-10-2003, 01:34 PM
speedy_g's Avatar
Default ??? - Problem with Turn Signals..
I have a problem with my left turn signals, they will not work when I activate them. I have replaced all the bulbs work and I still get nothing. The arking lights work when I use the switch but the left drl does not. The hazards work but turn does not. Any help would be appreciated.
Old 12-10-2003, 01:44 PM
bigMAC's Avatar
Replace the flasher. I had this same problem about a month ago. The flasher only cost about 3 dollars. The flasher is underneath the steering column by where your knees go.
Old 12-10-2003, 02:30 PM
Brandon_TA's Avatar
i just got my car out of the shop for this.. They had to replace my terminals. 3rd time in a year.
Get some new terminals. Driving in the rain will cause this.
Old 12-10-2003, 03:31 PM
Steve1969LS1's Avatar
This might get more help in the electronics forum
Old 12-11-2003, 07:14 AM
Ungrounded Moderator
WhiteBird00's Avatar
If one side works but the other doesn't then it is NEVER the flasher. Both side turn signals run through the same flasher. The system is designed to stop flashing on the side that has a bulb not working. This doesn't mean that it's always a bulb (although that's the most common problem). It could be a corroded socket (especially on the front - they seem to get water in them pretty easily), a bad ground or a broken connection someplace. If you've already replaced the bulb then the next thing to do is have a good look at the socket. If the socket looks OK, use a meter or test light to check for power and ground at the bulb contacts and trace back from there.
