Q about tweeters in door.
To use the CDT mount....you have to pop the tweeter out of the cup it is currently residing in. This is done by pushing the back of the tweeter through holes in the back of the cup. It is NOT easy to do and I use a piece of PVC pipe that just happended to be the same size as the tweeter cup but slightly smaller then the tweeter. I think it is 1" PVC. Anyway, if you lay it face down on that and pop the back it will pop out with some force behind it. You then put the cup on top of the bracket and the T-shaped thing behind it with the braket sandwiched between and put the sdcrew through the cup face down into the black CDT bracket. You then have to put the tweeter back into the cup with the screw underneith it.
Why they made it so difficult instead of just threading the dang tweeter...I do not know but that is how you do it.
Hope that helps!!
