Banging my head against a wall on my stereo..
I'm having some odd problems with my 01's radio. When I got it only the front two speakers would work. Looked and the back two were unplugged, when I plugged them in, still nothing. Oh well, no big deal. Then it started only one speaker at a time upfront would work, and if you hit a bump it would change sides or go out completely. Hit a bump and it may come back on.
I unwired the radio and put it back very well (I have an electronics background) and same problem. Swapped the head unit with another JVC i have and still the same problem. Harness looks good and all speakers are wired tight. Is there something I'm missing? My car is a stripper but I'd atleast like to keep the radio.
I don't know for sure but sounds like the same problem I have with the stock radio while playing cd's. I am guessing since radio has been changed it would be a short in the wiring along the way. Is this factory wiring for the speakers?
I do have a Monsoon system. Put a new amp from a 98 Camaro into it today to test it with no luck. When you plug the amp in or unplug it with the radio powered you can here a pop at the speakers, just like when you power up speakers.
