What color wires for power, ground, ACC, and illumination in 94 camaro?
Well I Have a 94 camaro that came with a bose system but instead of chasing down the speaker wire I just ran new ones since the amps were long gone! but the power wires make no sense to me, what colors are what? i just hooked up the stereo red and yellow to the car yellow to get it to work but everytime I turn the car off it loses momory and I have to reset EVERYTHING in the stereo! what is the correct wire colors?
Here are the wire uses according to modified life. Look to see if there is an orange some where. Most can manufactuers don't use standard coloring for their wires. If no one else knows off the top of their head, a multimeter can help you track down the one you need.
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6 1/2″
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6 1/2″
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Yellow
Left Rear Speaker Negative Wire (-): Brown
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
