Odd, very concerning question...
So I drove over to my sister's house (everything was fine and driving normally) and then I had to take my friend home. I start my car and my Check Gages light came on, so I'm like wtf? check gages? and I notice my battery gauge is in the red. So I pass it off and take my friend home thinking my alternator will charge my battery. Well halfway home my lights on my cluster get dim and my battery has dropped to a bit over 8 and then my ABS Inop light comes on... I make it back to my sister's and after I turned my engine off I try to start it again and it won't start. I went back out 30 minutes later and it started back up somehow but still had a low battery reading and this time my Service Vehicle light came on (this concerns me). I left my engine running and checked the serpentine belt and it wasn't broken. I don't know what the problem is, and I wouldn't think the battery dying would throw up the SV light. Any ideas? Thanks.
Save the manuals!
Step 1) Test the alternator.
Step 2) If battery old, replace it.
Step 3) Check the continuity of all the wiring.
Step 4) Get a new sister. She's obviously bad luck. Keep the friend. At least the car will run for him. I hope he's not dating your sister - that would be really messed up.
How can I test the alternator? I'm assuming I would need a voltmeter? I'm thinking it is just the battery going out since it's really old, but I wouldn't thinl the battery dying would throw the SV light. That's what I'm concerned most about, I want to know what's causing that light to show. I doubt it's the wiring since I haven't done any aftermarket wiring.
Does the Ol' unhook the battery with the car running test the alternator on these cars? Lol probably not, I'm just used to working on the old carburated junk. But I did work at Oreilly Autoparts for several years, and they will bring out about an $800 tester that does a pretty decent test of both your alternator and battery for free out in the parking lot.
Update: while trying to drive to my house this morning my car started up fine (still with low battery), but about halfway home all the gauges on my cluster fell to zero (MPH, tach, everything...) and my idle got really choppy including loss of power. Well my car eventually completely dies and I pull to the side of the road right in front of an Advance Auto Parts (oh the irony). I ask them to check my alternator and they tell me that it has to be running to check the alternator, but he checks my battery and explains to me that the alternator ran it dry trying to start itself up. So it's beginning to seem like my alternator is to blame.
I realize that, that's not what I meant. I'm already going to have to take out the alternator to replace it, I just wanted to save myself the potentially uneccessary job of removing the battery if I didn't need to. Simply trying to be efficient, I realize the battery is leaps and bounds easier to remove than the alternator. Regardless, is there a write up anywhere for doing an alternator swap? Me and one of my buddies are going to try to do the swap tomorrow night.
Well me and my buddy swapped the alternator yesterday and the car is idling just fine now (around 14-15 volts). I don't know what "technique" you were referring to. We just pushed the fan housing out of the way to give us the necessary clearance to get over the sway bar.
Save the manuals!
Glad to hear your full voltage again!
