Quick help!! Replacing camaro mid with TA Mids ?
Old 10-24-2010, 08:06 PM
Nastyc4's Avatar
Default Quick help!! Replacing camaro mid with TA Mids ?
Ok so my mods are dead on my TA and I was fortunate that a localforum member let me have his monsoon Mids. He has a TA and my miss say 2 ohm and his 4.
Can I run the TA speakers in 'series' making it a 2 ohm for the factory amp?? I just wanted some mid range I hooked up my amp and sub but i have it filtered Down real low and it still lacks the Mids hence the replacement.
Old 10-25-2010, 07:32 AM
Ungrounded Moderator
WhiteBird00's Avatar
Your first question and second question contradict each other. Your "mids" are in the doors but both Camaro and Firebird use 2-ohm speakers there, so I assume you mean the sail panel subs.
You can put Firebird subs in a Camaro by wiring them in parallel to get 2-ohm total impedance. Wiring them in series would produce an 8-ohm total impedance. To wire the dual voice coil Firebird speaker in parallel, connect both positive terminals to the positive wire and both negative terminals to the negative wire.
