Worth upgrading from Alpine Type-R to Type-X for my 10"???
Let me first off give you a quick overview of the car. I am in the process of sound deadening even the windows to give you an idea of the lengths I am going. I'm trying to create a vault from outside noise and am in it about $600 now.
My components are CDT's high end and the power is coming from a pair of beautiful and quite powerful Cadence amplifiers. No mid fill.
I currently have the alpine Type-R in the Stealthbox. However, the Cadence is capable of pushing a little more power than the R can handle.
Anywho...
I am now looking at the Alpine Type-X as a replacement for the Type-R. Any thoughts? I would prefer to just leave well enough alone unless the sound difference is completely out of this world amazing.
To make it easier-
Type R - - - - - - - - - - - - - - - - - - - - - -Type X
Pulp/fiber cone reinforced with Kevlar- - - - - Same
Santoprene rubber surround- - - - - - - - - - Same
Cast aluminum frame - - - - - - - - - - - - - -Same
Power range: 50-500 watts RMS - - - - - - - 500-1,000 watts RMS
Frequency response:26-500 Hz - - - - - - - - 26-200 Hz
Sensitivity: 85 dB- - - - - - - - - - - - - - - - 82 dB
Anywho...
To make it easier-
Not gaining that much by going with the Type-X. Actually your limiting your usable frequency range by going to a Type-X. I personally wouldn't bother because you have a slightly broader frequency range with the R.
What are you trying to accomplish by going to the Type-X, just more output? Just curious. The Type-X will put out more bass but the Type-R does pretty well also.
Thanks for the affirmation that it is in fact overboard. The fill is there, but that is good advice, so thanks again there. I can supply the 1k RMS, but the system is built for quality, not pure output. I have deadened the hell out of it to hear clear clarinet, violin, or trumpet highs, so in retrospect, it was a pretty stupid question, but thank you for not pointing that out!
Kee-
Thanks for the reality check. I honestly can't say what I was trying to accomplish. I guess it is one of those, "hey, look how cool that is. I probably need it" moments.
Thanks again, guys. I'll stick with what I got.
Kee-
Sounded to me like you were going for an nice SQ system. It also sounds like you have accomplished that for the most part.
I have had several of those moments where I just upgraded stuff and gained nothing. Especially when it comes to subs. I used to go bigger every year because of the wow factor. LOL!!
