Keyless Ignition & Entry Like the C6
Old 02-26-2012, 04:54 PM
  #41
Blasko's Avatar
How about if its running and you get out and walk away?
Old 02-27-2012, 09:47 AM
  #42
bad_408_vert's Avatar
You have to push the button again to turn the car off.
Even if you leave the car with the RFID fob in your pocket, car stays running.
Old 02-27-2012, 02:25 PM
  #43
No Juice's Avatar
I'm in to see a full write up......hopefully soon?
Old 02-27-2012, 02:59 PM
  #44
Someone give me a clean aka Easy way of disabling the steering wheel lock & I'm down to install this. Not really looking fwd to removing the air bag and such like metioned before.
Old 02-29-2012, 11:17 AM
  #45
jbro90's Avatar
So emenny81 what push to start or remote start did you go with man
Old 03-01-2012, 09:58 AM
  #46
Blasko's Avatar
I'm pretty sure the only way you can is by taking it all apart.
The steering whee; and airbad aren't that hard to take off, but I'm ot sure on an F Body how hard it'd be to disable the lock after you tear into it.
I kinda want one of these also.
Now to save up some money..
Old 03-01-2012, 08:33 PM
  #47
JOHNNY59's Avatar
I seen somewhere there is a kit that contains a solenoid that unlocks the steering wheel when the car is started and will relock when the engine is shutdown.
Old 03-01-2012, 10:58 PM
  #48
cancam99ss's Avatar
ohh i want this....
Old 03-03-2012, 11:00 PM
  #49
jbro90's Avatar
Well just because your timers removed vats dos so how did you of you did get past this problem mane not get you past the wheel lock you still have to have a key to unlock the steering wheel because it is mechanical
Old 03-04-2012, 10:26 AM
  #50
JOHNNY59's Avatar
can use a cut key to keep the wheel unlocked.
Old 03-07-2012, 01:12 PM
  #51
FrankSS's Avatar
if you do the push button start, will you still be able to bump the starter to turn the motor over if you need to do some maintenance? thats the only thing that I would need that I dont know if it will provide...
Old 03-13-2012, 04:55 PM
  #52
emenny81's Avatar
I shimmed the key !!!
Old 03-13-2012, 05:00 PM
  #53
emenny81's Avatar
Ive seen this kit as well but only for c4 covettes.
Old 03-13-2012, 06:52 PM
  #54
JOHNNY59's Avatar
the kit I seen was a universal one.
Old 03-14-2012, 08:52 AM
  #55
You are thinking of the mustang keyless. wwwdotmustangkeylessdotcom
That kit uses a servo to unlock the steering wheel. I personally think that kit is a hack job.
Old 03-21-2012, 08:10 PM
  #56
emenny81's Avatar
keep in mind that this universal kit is only made for mustang.
Old 03-22-2012, 01:13 PM
  #57
Pete137's Avatar
I intend for this to be one of my next purchases, and I plan on removing the steering wheel/air bag in order to remove the steering lock. So if I'm the first one to get this and install it (besides emmeny81), then I'll try my best to document the installation process and do a write up.
My only question is, does the VATS absolutely have to be tuned out? I need to take my car to a tuner for other things anyways. Just trying to figure out if I need to take her to a tuner before I install this or not.
Old 03-22-2012, 07:04 PM
  #58
luna123black's Avatar
My kit should be here in a day or 2. As far as vats I'm keeping it and using a bypass kit. Xtra security can't hurt.
Haven't decided on the wheel lock yet. For now I'm going to shim a key. Before I completely get rid of the ignition I need to be sure this is 100% reliable.
Old 03-22-2012, 07:10 PM
  #59
emenny81's Avatar
only way to disable VATS with out having the key in there is to have the tuner do it, I'll be really nice to see how you disable the steering wheel, I haven't done it because I believe you need a special tools to pull it.
Old 03-22-2012, 07:11 PM
  #60
emenny81's Avatar
what do you mean by bypass kit ???
what wire taps will you be using ?
Quick Reply: Keyless Ignition & Entry Like the C6
