Will the Auto Trix Passenger Fix kit work on the driver's side aswell?
title says it all really. I want to do it to both windows but since it's titled "Passenger Fix kit" I'm wondering if I can use it for the driver's side as well. Are they both wired the same way? My driver's side window's motor just died today and it's a bummer.
Oh I just found it, thanks.
God damn, it costs 100 more $ than the Passenger Kit? Wtf? I'm gonna have to think about this...
To the other guy, yes, it's an Express Down Kit, but it comes with the same stuff as the passenger's kit so I'm pretty sure it's the same thing except it comes with the one touch down thing.
Save the manuals!
Maybe it will reduce the interval between motor changes, but after you do it for the fifth time, it gets really easy.
Alright I'm just gonna buy this:
http://www.autozone.com/autozone/par...3_0_1264_78655
Do I need to buy a new regulator as well or is it just the motor?
Save the manuals!
That's the one. If you follow this method and instructions, you won't have to remove or replace the regulator. Once you do this one time and drill the holes, any future changes will go faster:
http://shbox.com/page/windowmotor.html
They don't fix anything, they just make a bad motor look good. Given that you can get a lifetime warranty motor for much less, I can't for the life of me understand where the value is in the kit.
I imagine the driver side kit is so much more expensive because it retains the express down feature. I'm sure there is a way to adapt the passenger side kit to work on the driver side, but express down would no longer work properly.
Save the manuals!
There is nothing wrong with the wires or wiring. People freak out when they see this myth and its simply not true. The wires are the same quality, using the same parts used on the rest of the car, and are routed no differently than many other car models on the road today.
The door wiring has some length to it when you measure from the battery. This introduces increased resistance, causing a small (and nominal) voltage drop. The Autotrix kit "works" by providing a shorter path from the battery, reducing resistance in the circuit, and increasing voltage by a small amount.
So, if the window circuits and windows work perfectly fine from the factory, we can't reasonably blame "the wiring" when performance degrades. The motors wear out - the wiring does not. When the motors wear out, providing them with increased voltage will boost their performance significantly. Considering that this exact motor design was first invented for and used on a 1969 car, with smaller and lighter windows, its no wonder there are problems.
The motors work fine from the factory, but I can guarantee you that if you took an fbody when it was brand new and installed the autotrix kit (or heck just made your own relay kit, it really isn't that hard, autotrix just has everything you need in a nice package), the motor would operate faster even then.
If the factory wiring is "just fine" and don't cause much voltage drop, and the autotrix only increases voltage by a "small amount" how does it even make such a noticeable difference? The answer is because the factory wiring causes a fairly large voltage drop. You have a long length of pretty thin wire running on a DC circuit that has a relatively high load - a prime setup for voltage drop.
Barring all that, we still go back to my previous comment - Why would you really want to replace motors 5 times when for the price of 1 motor you can install this kit and not have to replace the motor again? Or even if you did, it wouldn't need replaced 5 times through the life of the car. I think 5 times is a little bit of an exaggeration, but you came up with the number 5, not me, so I'm just using it
OP save some money and try this, let us know how it works.
https://ls1tech.com/forums/stereo-el...tors-pics.html
EDIT: Actually, I think it'll just be best to buy the Dorman motor and replace the OEM one. Both methods should deem the same result, but the soldering one is a bit harder than just replacing the shitty OEM motor with a good one that'll actually last.
going back to the ques. Will the $30 kit work for the driver side? i think i read somewhere it will work, you just need to wire the kit a little different. Has anyone tried this before? If so, how is it wired?
And from what I remember, the pass side power is routed through the driver's side switch. That is part of the problem.
Personally, i'd just do the thermal mod to the driver's side and call it good. The power is more direct on the driver's side. Pass side has to go through a lot more BS and that's where the voltage drop occurs.
