Monsoon Speakers
Old 06-10-2013, 02:43 PM
38DD2436's Avatar
Default Monsoon Speakers
2 of my original speakers are blown in my SS. I want to keep the factory stereo. What speaker options are available? I would like some thing better than stock. Also, are there any sponsors here?
Old 06-10-2013, 03:16 PM
Blownbayou's Avatar
Fronts, sail panels or rears?????
Old 06-10-2013, 06:35 PM
38DD2436's Avatar
I want to replace them all. Its a convertible.
Old 06-10-2013, 08:43 PM
Blownbayou's Avatar
check out the stickie on the monsoon radios..... all the speakers have different ohm ratings. Simple and easy way is to go with the vendor (kee audio) on the board. I think he makes a package with all the speakers needed for your vert
Old 06-11-2013, 09:12 AM
slt200mph's Avatar
As long as you keep using the monsoon (junk) head unit you will continue to blow speakers. It is of low quality and the signal it sends to your speakers is distorted. Which is why you blow speakers. I replaced door speakers and sail panel speakers many times. Then I switched out the monsoon head unit for an aftermarket head unit and all was well. I eventually upgraded my speakers put aftermarket door speakers sail panel speakers in the car. I still used the monsoon amp and the factory wiring and have never had a problem rockin out at high volumn since....
I got my sail panel speakers from Kee audio and they rock to say the least. Plus he is one of our supporting vendors and is local to me. A real good guy and he will not steer you wrong.
Old 06-11-2013, 09:21 AM
Blownbayou's Avatar
I have no issues with my aftermarket speakers and my Monsoon HU. I switched it out at first, but hated the look of the aftermarket radio. I am happy with my tape deck People always ask about the tape deck when they see it.
I run Infinitys up front (wired kinda like component), Kickers in the sails, Kickers in the rears and Infinity Basslink in the spare tire area.
Happy Happy Happy
Old 06-11-2013, 09:38 AM
slt200mph's Avatar
The aftermarket head unit that I used fits the 1 1/2 din size hole that the car came with. It is a Pioneer unit. I doubt that is still available as I put it in about 7 or 8 years ago. I get compliments on the sound system all the time. I looks good and sounds better. Beleive me when I tell you that the factory monsoon head unit is junk. Ask any auto sound professional that is familar with these cars and they will tell you the same thing. Your after market speakers are going to be harder to blow than the factory ones. But your sound quality will never be very good as long as you are hooked up the that monsoon head unit. Nuff said ... rock on dude...
Old 06-11-2013, 10:24 AM
BrntWS6's Avatar
I had to replace my first speaker in the sail panel a few weeks ago. Car only has 18k miles on it too....I do turn the music up quite loud when I drive though. I would have upgraded but really didn't want to cut all the ends off and replace with new ones. So I just ordered a new Monsoon off amazon and turned the bass down.
Old 06-12-2013, 05:28 AM
38DD2436's Avatar
OK, then speakers aren't the answer. Time to look for a HU.
Old 06-12-2013, 10:15 AM
ZL1Killa's Avatar
Kee Audio. buy the full kit from him and you won't be disappointed. I did mine a few months back
Old 06-13-2013, 10:13 AM
38DD2436's Avatar
Did you also replace your head unit? ^
Old 06-13-2013, 03:30 PM
Blownbayou's Avatar
Stock HU looks better..... sound difference is moot because I do not crank it all the way up. If you want sound, go with an aftermarket HU and the kee audio package.
Old 06-17-2013, 10:38 AM
FSUNole17's Avatar
You could try the JL Audio Cleansweep with your stock headunit. I hear it cleans up all that sound and retains the factory head unit while still allowing you to hook up external amps to aftermarket stuff.
Quick Reply: Monsoon Speakers
