Sub and Amp Mounting Question
I just purchased two 12'' subs, a Zenclosures sub box, and an amp. I am wondering where I can mount the amp and how to make the wires all hidden. I was thinking the most practical spot to mount the amp is right on top of the gas tank sense it will be right in front of the subs.
Let me know the best way to wire it so all the wires are hidden please! Here is the subs, amp, and sub box I bought.
Pioneer TSW310D4 12-Inch Champion Series Sub
SOUNDSTREAM RUB1.1000D Amp
1993-2003 Camaro - Firebird - Trans Am Subwoofer Box
Buy some mdf, mount it to that area using the bolts that hold those loops on back there. You can countersink the holes in the mdf or use risers to lift the amp. Drill holes for your wires. Add mdf blocks that run the width of the mounting board (creates channel underneath for the wires to run), carpet it and you're done. Did mine like this and it was pretty cheap and looks great. I'd recommend buying risers (lowes has them in the nuts/bolts area) and raising the amps for airflow.
