switchback led drl
switchback led drl
I put some in today from super bright leds and I was wondering what the best easiest route is for getting the flasher to work properly? I've heard you can just replace a fuse but I don't know if that is actually true most people talk about a flasher of some sort.. are any of those plug-n-play?
yes I saw that thread but I don't know where to get a flash relay or electronic flasher from, or how to install one. Don't even know where it goes. Don't know if there is a thread or someone who could explain it.
Ungrounded Moderator
As long as you convert only the front lamps to LED bulbs, you can replace the stock thermal flasher with any electronic 2-prong flasher such as the Tridon EL-12. They are available from a multitude of sources including auto parts stores and even Walmart. Amazon has them for less than $8.
The electronic flasher is a simple plug-in replacement for the factory one. You'll find the factory flasher under the dash clipped to the back side of the knee panel just to the right of the opening when you remove the access panel under the steering column (right above the OBD II port).
#1 - Turn signal flasher
#3 - OBD II port
If you convert your tail lights as well, you will need to use either load resistors or a specialized LED bulb flasher.
#3 - OBD II port
I understand the flashers now, but is there a way to keep the leds white when the headlights are off during the day? I didn't realize they would still be amber with the headlights off
LED switchback bulbs don't have a colored globe so they can use different colored LEDs but they still have to assign a single color to each circuit ("filament"). So the dim running light circuit uses white LEDs and the bright turn signal and DRL circuit uses amber LEDs. That means that as long as the headlights aren't on, the LED bulbs will always be amber. They will only be white when the headlights are on and the turn signals are not in use.
As wssix99 has mentioned, you would have to rewire the DRL module in the dash to make the DRLs use the running light circuit instead of the turn signal circuit. That would not be a minor modification.
haha yea definitely beyond what I want to get involved with , well nonetheless they look way better now with new housings and leds. thanks for all the good info gonna pick up a flasher at autozone in a bit.
Getting rid of the yellow light during daytime
If you unplug the DRL box behide the radio it will get rid of the yellow in your switchbacks and use the white. the CON is that you lose the DRL and the auto headlights function.
If you want to do this all you have to do if take the stereo out (no need to unplug it) and look for a black box about the size of a cigarette pack. Pull up on the box and it will have two sets of wires plugged into it. Unplug the BLUE clip set of wires. Put everything back on and its done.
There are better ways to eliminate the DRL circuit if you want to do that. Personally, I think the amber DRLs (especially with good LED bulbs) are a useful safety feature and look much better than the ones that use the headlights.
The problem with that is that it makes your turn signals white instead of amber. While that is technically legal, I can't think of any vehicle that comes with white turn signals so it is not the safest way to configure your lights (oncoming drivers won't expect white flashing turn signals).
Save the manuals!
White turn signals are illegal. The fronts need to be Amber and the rears can be amber or red.
The DRL's can be white.
The regulations for the US are in table 1-A of this regulation: http://www.ecfr.gov/cgi-bin/text-idx..._1108&rgn=div8
The white vs amber front signal laws vary by state. For example, here in Florida the law states:
Federal law normally takes precedence but that just means that states can't enact laws that are more restrictive than federal requirements (e.g. my favorite is states trying to outlaw motorcycle modulating headlights which are legal in all states under federal law). That means that Florida and other states are free to allow white front turn signals even though they aren't covered under the federal regulations. I don't know if any other states do so.
Manufacturers don't build cars with white turn signals because they need to be able to sell everywhere in the country but individuals can make the change (at least in Florida) without risking a ticket.
That still leaves it as a dumb idea.
Florida Statutes 316.234(2)
Any vehicle may be equipped and, when required under s. 316.222(2), shall be equipped with electric turn signals which shall indicate an intention to turn by flashing lights showing to the front and rear of a vehicle or on a combination of vehicles on the side of the vehicle or combination toward which the turn is to be made. The lamps showing to the front shall be mounted on the same level and as widely spaced laterally as practicable and, when signaling, shall emit white or amber light. The lamps showing to the rear shall be mounted on the same level and as widely spaced laterally as practicable, and, when signaling, shall emit a red or amber light. Turn signal lamps on vehicles 80 inches or more in overall width shall be visible from a distance of not less than 500 feet to the front and rear in normal sunlight, and an object, material, or covering that alters the lamp’s visibility from a distance of 500 feet to the front or rear in normal sunlight may not be placed, displayed, installed, affixed, or applied over a turn signal lamp. Turn signal lamps on vehicles less than 80 inches wide shall be visible at a distance of not less than 300 feet to the front and rear in normal sunlight, and an object, material, or covering that alters the lamp’s visibility from a distance of 300 feet to the front or rear in normal sunlight may not be placed, displayed, installed, affixed, or applied over a turn signal lamp. Turn signal lamps may, but need not be, incorporated in other lamps on the vehicle.
