How would you wire these?
Ungrounded Moderator
Perhaps you are confusing a crossover for a tweeter. The tweeter is the small speaker in your hand in the fourth photo. There is no such thing as a dual voice coil tweeter so it should have only one pair of wires.
The crossover is a box that is used to split the audio signal into high frequency for the tweeter and lower frequencies for the mid. It would have a place to connect two input wires and four output wires. The Monsoon system already filters the signal like that so the crossover is not needed for your installation. One pair of factory wires will go directly to the tweeter and the other pair will go to the mid (red = positive, black = negative). If you trace the red and black wires a little farther into the harness, you will see the colors change to match the listing in the Monsoon FAQ so you can determine which pair is which.
