DRL Problem
You may have encountered a used DRL module that has been modified by the previous owner to eliminate DRLs. This is done by soldering together two traces on the module's circuit board (marked A and B on this photo): DRL Disable. If so, cutting or desoldering the connection should restore your DRLs.
Still, I'm curious how you came to the conclusion that your DRL module was damaged. The black and brown wires at the socket would be ground and parking light power respectively so reversing them would have shorted your parking lights to ground and blown the TAIL LPS fuse. That should not have had any effect on your DRL module.
