where to buy: Pot for volume on monsoon radio?
i have 4 ls cars and 3 of them need new pots for the volume. I found a part number on the one i just took apart, 9844 MAL, but have had no luck finding anything.
tia
tia
i didnt, i figured it was worn internally to the point needing to be replaced. i have some crc so i will give it a shot but I really don't see how it will be effective.
Ungrounded Moderator
I agree with M4N14C... electronics cleaner usually does wonders with the volume control. More often than not it is years of grime build up rather than physical wear that causes such symptoms as volume changing on its own, non-responsiveness, gaps in the volume control range, etc.
I have not researched replacement pots but I can try to see if any are available commercially. Certainly there are companies that repair and recondition Delco head units but I don't know if they sell parts at retail.
I didn't expect that to be the case so thanks to both of you. I would still like to have replacement info if you can find it in case the problem isn't resolved. i am waiting on bulbs to arrive to reassemble the one on the bench, i'll update at that point.
I have since found that there is another set of numbers on the pot, 16208722 if its of any assistance.
Thanks again for the help guys.
my issue on the 2 i have is that it is not linear turning up or down anymore, skips to high volume levels mostly. if i put some perpendicular pressure on it i can usually get it to function but that's annoying. the unit looks fairly tight and i don't have tools small enough to attempt disassembly.
they both needed lights for the readout. they have arrived and assembly should be done as soon as i get the aux port pieces in.
