Good 10inch sub ???
Good 10inch sub ???
Just looking to run a 10 inch sub with maybe that box they make to fit in the passenger side rear panel. Is this a good option and placement for these f bodies? Not looking for anything crazy, just 200-400rms? Any opinions on what box, amp, and sub i should get. I have a good clarion head unit already installed. Thanks.
I have an Alpine type R. Its 10" and its in one of those custom boxes for the side of fbody hatches. It sounds really clean. Its connected to a kicker amp and its more than enough. I think its around 1000watts rms. The amp is placed where the spare tire used to be. My only concern was overheating in 112*+ weather but so far no problem.
I would recommend an Alpine Type S, or a Kicker Comp R. Both will have somewhat close RMS power handling, and both will give you nice, clean bass.
Pick an amp in the 300-400 RMS range. Avoid Pioneer and Kenwood. Kicker also makes great amps.
Aftermarket stereo or factory? If factory you'll need a Line Out Converter, and make sure you get a decent quality one.
A shallow mount sundown audio 10 in a .75 cf box with 300rms clean will sound nice. It'll cost more then some of the subs recommend but it'll last forever and if you want it could handle a ton more power.
Sounds Solutions Audio makes some badass subs might want to check them out. The 10" DCON would be perfect for your needs. I'll be running a 12" XCON but thats a whole different animal and install. Their subs are built and preform extremely well and are MADE IN AMERICA!
I'm using a 10" Pioneer champion sub. It's around 350RMS. It hits hard with great midbass, and I'm using a box not built to spec. Clarity and response is excellent. And best of all, it was like $80 shipped to my door.
