double din head unit/ back up camera 4th gen
hi, i just purchased my 3rd ls fbody. its an 02 ss m6 without the moonson system. i've grown accustomed to having a back up camera. I've installed head units before, but they have always been plug in play. i was looking at purchasing either of these.
https://www.crutchfield.com/p_130290...tp=20217&avf=Y
https://www.crutchfield.com/p_613DDX...tp=20217&avf=Y
I'm ordering a new double din face plate from crutchfield. I know I have to cut the plastic support in the back. I know that i should tap into the power for the reverse lights for the camera, my question is, its telling me that i have to buy
https://www.crutchfield.com/p_120701...g-Harness.html
do I have to hack up the stock wiring harness with this to make the new head unit to work?
I'm also open to suggestions. i only want bluetooth, to be able to hook my phone up to it and a rear cam. the stock stereo sounds fine to me, so i'm not looking at changing or adding speakers.
thanks for any help
thanks for any help
Yes, You'll need that half f-body wire harness (as crutchfield shows) to wire the new radio in!
The new radio will include the other 1/2 for itself. You wont cut any stock wiring. Just solder the wires from the Radio harness to the crutchfield harness.
A tip: Most GM harnesses do NOT include a wire for the "Dimmer" function. I couodnt find a "complete" harness, so I bought a 2nd harness to remove 1 wire, and install it into the crutchfield one.
Thanks for the tip
