Write Up. Wideband install in the factory cluster.
Old Apr 10, 2017 | 11:23 PM
MY_2K_Z's Avatar
Default Write Up. Wideband install in the factory cluster.
So I'm not a huge fan of pillars pods and decided to do something different with my wideband install. Here's how I did it and how it turned out.
First remove your cluster and completely disassemble it. Leave you with the face plate and the white plastic backing.
So this is where it will be going. The "wasted" space where your warning lights would be.
Next take the face of the gauge, place it here and trace it with a sharpie. Now cut the circle out with a razor blade. All that is being cut at this point is the thin plastic face plate and doesn't require much force.
Next you will need to cut out the honeycomb portion of the white backing. This is where the leds shine through to the cluster but will no longer be used.
Next you will have to grind 2 flat spots in the threaded portion of the wideband gauge.
Line your wideband up against the clear portion of the backing and mark the 2 areas that touch the clear backing. Now grind them flat and test fit.Name:  888FCDE1-CCF6-4952-B977-2722768B58E3_zps9eqq979a.jpg
Size:  265.7 KB Make sure the gauge is level so once completed it's not crooked.
Size:  238.6 KBName:  CE4A4258-4E32-4624-AD30-ADBDCFDEECD6_zpsa7wt0eyy.jpg
Size:  241.4 KBName:  C0EF43BE-27DE-432E-8B72-69278235C516_zpsu7wxvqgs.jpg
Now test fit the white backing on the face plate with the gauge in place. Grind down any areas that still make contact.
Once your happy with how everything fits you will place the gauge on the black face plate and 2 part epoxy it to the faceplate. I used Jb's weld but I'm sure other brands would work as well.
Allow that to dry overnight and then reinstall the white backing. Name:  433706C6-4DA6-44B0-9224-8A4639702A02_zpseslsbxsl.jpg
Size:  271.6 KBName:  7B123657-22C6-422E-B826-BD78E7F69B46_zpsjq32aofv.jpg
Before your finish assembly of the cluster you will have to hook up the 2 plugs for the wideband then assemble like this.
Size:  160.4 KBName:  9F3E766F-95E1-4C8D-9BEB-E5171E79F8F7_zpsyeegjm6x.jpg
Now install the cluster and wire the wideband and admire your work.
Finished product
https://youtu.be/b3il4CwLkfc
Old Apr 12, 2017 | 10:39 AM
Photochop's Avatar
Very nice work!
Old Apr 12, 2017 | 11:48 PM
MY_2K_Z's Avatar
Thanks, I thought it would be pretty cool and different. I don't think I've ever seen anyone put a gauge in the factory cluster.
Old Apr 21, 2017 | 09:09 AM
bleepster's Avatar
very cool. nice job.
Old Apr 21, 2017 | 09:33 AM
blackbyrd's Avatar
no thats definitely unique, I think I saw you post this in your build thread but I totally missed it it was so subtle.
smooth work for sure
Old May 6, 2017 | 11:41 AM
cancam99ss's Avatar
ok thats pretty cool
