Camaro front door speaker install-might had wired it wrong
So I bought a cheap pair of Pioneer 3 way 4-ohm speakers on CL. the speakers are coaxial and just realize that I should had looked/bought speakers that are components
so I found this thread https://ls1tech.com/forums/stereo-el...ent-setup.html
so should I just snip the wires that I soldered that's linked to the tweeters?
fwiw I have an aftermarket head unit and have a subwoofer in the back.
currently the front speakers work but as I turn the volume up the speakers get scratchy.
Ungrounded Moderator
The ideal situation is installing component speakers in the doors but coaxially mounted component options are limited. The next best option is to modify a normal coaxial speaker to separate the tweeter so that you can still use the separate channels from the Monsoon amp but some coaxial speakers aren't easily modified that way. If neither of those options are available, connect your coaxial speakers to the original woofer wires and tape up the tweeter wires so that they don't short out. The woofer wires get full-range (unfiltered) signal and the coaxial speaker's built-in crossover will take care of the tweeter.
I see. I do have the monsoon system (black box behind passenger hatch area). however the 2 front door speakers are blown and cracking when I turn the volume up.
how would I bypass the monsoon amp and run straight from the head unit? there's 4 wires from the front door speakers, the +/- midrange and the +/- tweeters.
Bypassing the Monsoon amp is a foolish thing to do. The Monsoon amp is not particularly powerful but it provides more power than the head unit alone and it produces output into eight channels with signal filtering to shape the sound for the environment. It provides clean output when given clean input so saying that the sound quality will improve by eliminating it is misinformed.
The factory head unit is a distortion machine and the primary source of sound quality complaints about Monsoon systems but you've already replaced that so removing the amp won't help at all.
If you find that the Monsoon amp doesn't give you enough power or flexibility then rewiring and installing a good aftermarket amp is the way to go. Your options then are limited only by your budget. But bypassing the Monsoon amp and running head unit alone to improve sound is dumb.
i am running an aftermarket amp that powers the subwoofer fwiw.
its a cheapo one i got from advance auto
http://shop.agreatertown.com/auto_pa...0295_000155435
Yes, adding a separate amp and sub to a Monsoon system is a common upgrade that provides more bass without major modification to the system. That's generally as far as you can go without changing to a completely aftermarket system (4-channel amp, speakers, wiring).
