Has anyone found a way to route a power cable through the firewallon the drivers side
Adding a 10 in sub/amp in the cubby on the driver side trunk, but can't figure a way to route a power wire (8ga) to the Alt Batt terminal without crossing over the width of the car to run through the pass through under the ECM without drilling a new hole. I guess if I have to use the ECM pass through then I don't need to use the Alt Batt terminal - can go directly to the Battery.
I got the M6 so the clutch pass through is not an option for me.
did a pretty thorough search, but could only find the ECM pass through or clutch pass through suggestions. Surely someone has a good routing solution through the firewall on the driver side...
my amp is somewhat in the middle of the trunk where the T-tops would be and I have the amp gauge wire running alongside the inner passenger chassis running underneath the plastic door cover and up alongside the passenger kick panel and through the hle where the pcm wiring harness is going. from there out along the engine bay fender and with inline fuse then battery positive.
Yupp. That's my plan for tomorrow. I didn't like the power wire hook up prospects on the Battery. Gonna drill a hole on the driver side firewall. Seems to be plenty of real estate available to run the power wire if your willing to drill a new hole
No... it's NOT photoshopped
