Double din, Pioneer SPH-DA120 & Apple Carplay
Hi,
I thought I'd share a couple of photos of the double din bezel and Pioneer SPH-DA120 I installed last year. This is hands down my favorite improvement made to the car if for only one reason: Apple Carplay. Carplay provides a great experience for the iPhone crowd. The GPS and handsfree tech is seamless. With a few more cables, you can run dash command from the Pioneer head unit (which I did) and is a real treat for track day!
The backup camera is awesome too! The look is nearly factory. The Metra bezel is a pretty good fit. Not perfect but pretty good. I have a spare bezel for sale in market place FYI. The cable routing in the back is a very tight fit (I'm using both USB ports, the HDMI port all the RCA's including the backup camera). I ended up ordering 90° USB and HDMI jumpers to make it all work. A pain in the *** to align but it all fits and works great. I also had to buy an Apple HDMI to lighting converter to run Dash Command. When it's all said and done, the system works beautifully.
VERY similar to my set-up...even with the SLP shift ****!
https://ls1tech.com/forums/stereo-el...t-no-gaps.html
Did you paint your bezel to match? I bought mine from Double D Mods, back when they were a sponsor and they were selling pained to match Metra bezels. If you did NOT get if from Double D Mods, I'm curious what paint you used to get it to match the '98 gray interior.
I did the backup camera as well along with the microphone and integrated GPS. (I don't use the integrated GPS as the iPhone GPS integrates seamlessly). The backup cam is great. It's tucked in the license plate pocket and fastened from above. That little camera was $10 on amazon and the picture is very sharp.
I have the same USB input with AUX input as well. I drilled a hole inside the console cubby and installed it in there. That way I can just put my phone away in there and everything is hidden.
The car was equipped with MB quart component speakers and crossovers along with an amp and sub back when I bought it about 10 yrs ago. I did upgrade the sub a few years back. Last year I installed foil backed deadening and a layer of carpet padding to insulate the interior. The result was a huge reduction of exterior noise and drone. And with the AC on, the interior stays cold much longer in the summer. Here's a pic of the deadening and one of the crossovers. I was about 3/4 thru installing the foil backed deadening in that pic.
I did replace the factory sail panel speakers with an appropriate replacement speaker when I installed the head unit. I forget the brand.
Looks excellent. I’ve been severely torn between keeping my 02 SOM original-ish and modernizing. This thread has me favoring the latter now. Great time to replace/upgrade the carpet, add material for sound deadening, and upgrade the audio system. Gotta love CarPlay. Also, can’t forget to throw in a couple of Corbeau sport leather seats to tie the package together.
Sad thing this is just some of the broader points of the interior and doesn’t take into account exterior renovations. If my wallet only knew, it would run for its life.
clean install I really like the usb port that you put in place of the cigarette lighter. What backup camera did you install? Also do you happen to have a pic of what it looks like mounted? Im interested ion adding a backup camera to mine, already have an older pioneer double din.
