Will Polk Audio component speakers fit?
I like the looks of the Polk Audio db5250 component set (5 1/4" and 1" tweeter) for the front doors.
Then there are the db6750 component set (6 3/4" and 1" tweeter) for the rear seats replacing my blown factory 6.5", and put the 1" tweeters in the hatch. They come with their own crossovers I think. Does anyone know if they will fit? I think they will be driven OK with the factory Monsoon amp. Tweeters will be run off the head unit like stock. Will this work???
Put the 6750s in the FRONT and the others in the back seat locations. Fronts SHOULD fit right in, I'll know first hand very soon. Rears either will fit as is or require an adapter you can get at any Best Buy.
It should fit. I recently replaced my stock Monsoon system with rockford components in the front and pioneer 6x7 in the rear. However, I wasn't able to mount them to the plastic trim that the rear speakers set into. The magnet was too big that the speaker just stood out instead of looking flush. Any one have ideas I could do about that?
