Was power antenna available for 2001 Camaro?
That is one option I really miss on this car, the power antenna. Its also a pain since I have a lift in a low height garage, I have to take the stupid thing off every time I lift the car. If I find a factory antenna somewhere will the wiring be in the car already? Also, what cars also use the same antenna?
Copy & Paste Moderator
No a power antenna was not an option on the Camaro, but you can add it yourself. Here is a write-up:
http://www.blackcamaro.com/antenna.htm
thats a very good write up. I used it just a week ago to install my power antenna. You can also put a switch in the remote line that you run (mentioned in that write up) so that you can keep the antenna down when your listening to CD's etc. I've found i can listen to most stations w/ it down. A writeup for the switch can be found here:
http://smiley.tzo.com/fbody/pas.htm
