installing 4 channel amp
Old 01-21-2006, 02:27 PM
schiccc's Avatar
Default installing 4 channel amp
i have a 4 channel mtx amp and 2 sets of audiobahn 6.5 speakers sitting around and want to install them in my car. i plan on running new speaker wire to the sail panel speakers from the amp what the easiest way to run wire to the front door speakers. is there away to tap into the factory wiring or do i have to run it directlty to the the new speakers.
Old 01-21-2006, 03:46 PM
Jpr5690's Avatar
in the spare tire well you can unplug the factory amp and pull the speaker wires that connection i.e. replace the factory amp with the 4 channel (but you will need a new power and ground)
