so you want to replace your cluster with aftermarket gauges??
Old 03-27-2012, 09:31 PM
  #61
Fosnot's Avatar
So anyway to use this for 98 -> LS1 corvette gauge cluster?
Old 03-16-2016, 06:03 PM
  #62
dcarpus16's Avatar
Default Check Gauges
Is there a way to wiring up check gauges light with an aftermarket cluster?
Old 03-17-2016, 03:19 PM
  #63
imma_stocker's Avatar
check gauges light???
Check Engine Light, aka SES, is working on my car. Can't remember which pin but the light is ground activated. The harness is ground, connect the other end to IGN 12V.
If using a normal bulb simply connect the wires.
If using LED connect harness wire as ground, then red wire to IGN 12V (reverse of other connections like turn signals). Be aware, the LED stays dimly lit when a normal bulb will be OFF. Nothing to worry about as the LED will be very bright when ON so there won't be any confusion.
Old 03-17-2016, 05:34 PM
  #64
dcarpus16's Avatar
I already have the check engine light wired up, but the LS1 gauge cluster also has a check gauges light for when a gauge goes to an extreme, (low gas, high temp, low pressure, low voltage) and I know it's signaled from the serial data wire on the 99-02 clusters, but I was hoping I could get that light to work on my after market cluster I made
Old 03-17-2016, 06:29 PM
  #65
Oh never saw those lights on the stock cluster. Post back if you find out.
Old 04-24-2018, 07:19 PM
  #66
Michael Henry's Avatar
Default Gas Gage 98 camaro
so if don't have a pcm want to put in a fuel gauge how would I wire it
Old 04-25-2018, 02:01 PM
  #67
biketopia's Avatar
This was from a thread about 10 years old, but that's the ohm readings you need for your gauge to read right at full and empty. Also a lead on a possible source for one. To hook up to it you need get a hold of a wiring diagram for your fuel level sender and see where you can get the signal wires from and then wire them in appropriately into your gauge.
Originally Posted by tha dingle
99+ LS1's (plastic tanks) are 33 Ohms Empty and 240 Ohms full. Autometer sells a gauge with these Ohms settings but it is backwards. I have heard autometer has a reverse aircore they will install in the gauge for $12 and make it work with 99+.
Old 04-25-2018, 02:03 PM
  #68
Power to power, ground to fuel level signal.
Fuel level reads resistance from the float.
IIRC the 98s have a traditional GM 0-90 ohm so pretty much anything stated for Chevy should work fine.
The correct wire was purple on my 02, that wire should run from bulkhead behind rear seats along driver side up and behind the dash back to the PCM. I cut and used the OEM wire somewhere near the fuse panel.
Old 04-25-2018, 02:10 PM
  #69
biketopia's Avatar
Well there ya go, and Chevy is pretty sweet about using the same wires for ever, my 95 was also purple I believe.
Quick Reply: so you want to replace your cluster with aftermarket gauges??
