Remote Wire with Stock Monsoon
Where would you tie in a remote wire into a stock Monsoon system. Is there somewhere on the head unit or the amp where you can tie in a remote wire.
Ungrounded Moderator
The Camaro has power antenna output from the head unit - there just isn't a wire in the harness connected to it. You can add a wire to position 8 of the black 10-pin connector on the back of the radio (this is where the pink power antenna wire is located on the Firebird).
