Replacing front speakers. How do you get the door panel off?
Old 02-10-2006, 03:00 PM
Okie02's Avatar
Default Replacing front speakers. How do you get the door panel off?
Well i took the plunge and bought some replacement speakers for the front doors but i cant figure out how to get the door panel off to gain access to the stock speakers. Can someone tell me how to?
Old 02-10-2006, 03:52 PM
Black30thz's Avatar
first you pop the power lock/wndow control off with a screwdriver take off the electrical connections,then you un screw the door handle plastic cover, the manual lock just pops out, there are a few screws(not too hard to find) on the door(in the armrest, behind the handle, in the holder, etc.) there is also a small triangle piece with a few screws at the opposite side as the mirror. then the door will pull up maybe an inch or two then pull toward you. don't forget to disconnect the -battery cable first
Old 02-10-2006, 04:28 PM
Okie02's Avatar
ok thanks
