power locks?
Old 07-15-2006, 12:53 AM
98bluez28's Avatar
Default power locks?
ok me and a friend tried the progressive door lock bypass on his camaro and now when you press the lock or unlock button the doors will not lock or unlock... what could be causing this? how can we fix it?
EDIT... the buttons on the doors will not work either.. when i press the button on the remote it sounds like its trying to unlock it but its not putting power out to the locks from the relay.
Old 07-15-2006, 03:37 PM
Ungrounded Moderator
WhiteBird00's Avatar
Check the fuses, especially the COURTESY fuse. It's not uncommon for the fuse to blow while doing the progressive door lock mod.
Old 07-15-2006, 03:49 PM
brock417's Avatar
yea when i did it the fuse blew and took me a min to thank to look at that fuse
