LS2 to LS1 cam sensor adapter?
I'm putting an LS2 into a car with an LS1 computer. I wanted to know where to get the adapter that will convert the signal from the LS2 cam sensor into something that the LS1 computer will understand. Please tell me where to find this. Thank you.
Brian
Brian
Racetronix carries them. It's just an extension harness, to lengthen the wire for the new location of the sensor. There is no difference in communication.
There may however be a different number of pulses if you you a stock ls2 timing chain gear.. not sure as the one we did had an aftermarket timing set.
