Whinning..
Whinning..
My car only has 4 speakers in it right now plus the 2 subs, 2 amps and a cap.. Well when I turn my car on the speakers whine and when i would step on the gas peddle the whine would get louder.. I take it there is a interference somewhere but I have no idea even where to start and look....
Anyone know?
Anyone know?
You could try grounding your head unit to the floor. It might be better if your amps aren't grounded to the same point, but i'm not sure if that would cause noise or not. Also what type of head unit is it? Pioneers have a microfuse in them that blows every once in awhile and it tries to ground through the rca's. If you could switch it out for another one that would be good.
Kleeborp the Moderator™
I had this problem once upon a time...I tried regrounding the head unit to four different places, all various distances away, and nothing helped. I dug up the wiring (I had someone else install my sub - BIG mistake), and found the RCAs were running right next to the power wire.
I personally fixed it by running the power down the passenger side (straight off the battery), and the RCAs down the driver's side. No issues since this change, and I've had two alternators **** the bed on me in the meantime.
