Trans Am headlight issue
Old 10-20-2007, 11:10 PM
=Tac='s Avatar
Default Trans Am headlight issue
This started about a week ago, i was leaving in the early morning and turned my parking lights on and noticed my headlights were up (but not on) when they shouldnt have been. Turned the light off and the driver side headlight motor was making a loud noise. Turns out once the light is down it continues to try and close is for about 5 seconds then quits. Also, when I lock or unlock to doors with the keyless the headlight go up and down. Wonder if the motor is on its way out and causing these problems, or if its something else.
Thanks.
Old 10-21-2007, 10:03 AM
Ungrounded Moderator
WhiteBird00's Avatar
A dealer would tell you that the headlight motors need to be replaced because GM doesn't sell repair parts. But really only the plastic gear inside the motor is damaged. In fact, only half of the gear is damaged. You can disassemble the motor and rotate the gear 180 degrees to use the undamaged side or you can buy brass replacement gears. More information is available in the Frequently Asked Questions sticky at the top of the forum.
Old 10-21-2007, 10:47 AM
KEE AUDIO's Avatar
Actually you don't have to dissassemble the motor just yet. Just remove the arm that connects the motor to the headlight assembly and then using a allen head screw driver rotate the gear 180 degrees manually by using the wheel on top of the motor...you'll have to remove the rubber cover over it. Make sure you pay attention to which way the gear was pointed so you rotate 180. You can tell because their is flat spots on the shaft you can use as a reference. Also, make sure the 4 tabs that are bent around the plastic gear housing are pushed against the metal gear motor tightly. This is the real reason the gears fail. The tabs get loose over time and it allows play between the plastic gear and the metal worm drive thus stripping the ends of the plastic gear.
For more info on the "free" fix and brass gears check out Brent Frankers web site. He even has a video on headlight motor replacement and sells brass gears. Keep in mind though the brass ones will only last if you make sure the housings are tight against each other. Otherwise the brass gears strip too. Try the 180 free fix first though!! Good luck!!
Old 10-21-2007, 06:08 PM
Copy & Paste Moderator
VIP1's Avatar
Check out this sticky in the Pontiac Firebird section:
https://ls1tech.com/forums/pontiac-firebird-1967-2002/177470-firebird-headlights-all-comments-questions-regarding-headlights-go-here.html
Old 10-21-2007, 10:23 PM
=Tac='s Avatar
Thanks for the input guys, no more annoying headlights
