Stock amp/aftermarket HU ?'s
Can I used the stock amp with say an Alpine H/U? Do I have to buy an connector? I tried looking in the stickies and couldnt find my answer. Thanks for helping, I know it will be an easy answer for some!
Its for a 99 T/A if that makes any difference.
So the plug in (for the stock amp) comes with the harness? I have only done 1 install in my life and it was like 4 years ago. As for the steering wheel adapter and antenna adapter, would best buy carry them? If not whats a good site to get them on? Crutchfield? Or anywhere cheaper?
at all cost dont use the factory amp they sound like garbage and they probably put out less then a new hu would find a bypass harness and unplug the factory amp in the rear and bypass it or have someone experienced bypass it for you and you dont need the harness
Copy & Paste Moderator
PAC makes adapters to retain the steering wheel controls. PAC SWI-X is the universal IR adapter that should work with almost any headunit with an IR remote. PAC also makes manufacturer specific adapters for headunits with a provision for a wired remote input. Example: SWI-PS works with Pioneer & Sony. Those adapters cost about $50-$70.
Ian (Kee Audio) has a really nice dash kit for the HU.
I'm running an aftermarket HU and aftermarket speakers all the way around and running off the stock amp. Works fine, even considering that the subs weren't even made for a car but I "rigged" them to work lol. Though the GM oversize mounting was a pain to work with in the doors and sails
