Bad rattle from the tail lights and trunk panal what to do?????
Old 12-30-2007, 11:36 AM
coreygalyk13's Avatar
Default Bad rattle from the tail lights and trunk panal what to do?????
i have one rockford p3 with a 1000 watt amp and even though its not much it still rattles the crap out of my tail lights and the panel in between them. My question is what have you guys done that has helped tame this down any help is appriciated and yes i know ill hear dynamat lol.....
Old 12-30-2007, 11:35 PM
bmnicolosi's Avatar
i sprayed liquid dynamat, tighted the bolts, then added dynamat sheets to my old camaro and it worked fine--no rattles. i had 2 l7 10's, ported running off of a kicker 1200.1.
Old 12-31-2007, 11:29 PM
98camZ's Avatar
easy answer turn ur damn sub down!!! and tighten the bolts
Old 01-01-2008, 12:09 PM
boola1341's Avatar
i'm having the same problem with 2 12's and a ma audio 1800 watt amp. I'm going to try and put dynomat or something like it behind everything that rattles.
Old 01-01-2008, 07:59 PM
Ungrounded Moderator
WhiteBird00's Avatar
That's the best answer to ghetto blasters!
Old 01-02-2008, 08:01 PM
impact1968's Avatar
I'd say turn it up and hopefully the rattle dosen't get louder too.
Old 01-02-2008, 08:42 PM
dragonrage's Avatar
Just use foam, shouldn't need dynamat
Quick Reply: Bad rattle from the tail lights and trunk panal what to do?????
