Foglights went out
Old 01-24-2008, 11:07 PM
unbroken's Avatar
Default Foglights went out
My foglights quit about a week ago. Switch lights up but they dont. They are new 37 watt 884s, and I tested them they are still good. Is there another fuse or circuit breaker? i found the one by the battery but how to know its good or bad?
Old 01-25-2008, 07:18 AM
Ungrounded Moderator
WhiteBird00's Avatar
Camaro or Firebird? It makes a big difference because the two have their fog lights wired differently.
In a Camaro, the ON indicator light gets power right at the switch so it really only indicates that the switch is working. That probably means that your fog light relay under the hood is bad.
In a Firebird, the ON indicator light is powered from downstream of the relay so it tells you whether both the switch and the relay are working. In that case there has to be a wiring problem between the relay and the lamps or the lamps have bad grounds.
Old 01-25-2008, 03:24 PM
unbroken's Avatar
sorry...2000 z28. So the relay at the box by the battery is probably toast?
Old 01-25-2008, 04:57 PM
There could be other causes but that is by far the most likely. You can test it fairly easily. The relay is in junction block #1 under the hood on the left fenderwell. Pull out the relay and use a short piece of wire to jump the brown wire to the purple wire. If the fog lights go on then you know the relay is bad.
Old 01-25-2008, 05:25 PM
unbroken's Avatar
thanks
Old 01-26-2008, 03:23 PM
unbroken's Avatar
Okay I checked the relay doing the wire trik. No luck. I tested the bulbs and they still light up(off the car) So it must be a wiring issue inline....
Old 01-26-2008, 10:34 PM
Chattanooga's Avatar
dumb, i know but...
Are your brights on?
I know when i first got my 95 camaro, my switch was out and the highs wouldnt go off, so the foglights were never on, and i thought they were broke..
Old 01-27-2008, 01:59 PM
unbroken's Avatar
Headlights work/highbeams also Normal. So Im going to trace wires now.
Old 01-27-2008, 02:02 PM
Siwel's Avatar
Being as low wattage as they are this is a slim possibility, but I have seen fogs draw too much power thus melting the power feed wire to them.
