Automatic Headlight Problems? Help!
I just bought anther 99' Trans Am. I brought it home today and started it up in the garage and the lights flipped up and came on. I thought maybe something was wrong but when I pulled it out into the daylight, they went down after about a minute and visa versa.
Am I correct that none of them came with automatic lights? Could the guy before me have put them in?
Also, I can't turn them off at all. So everytime I start it in my garage, the lights pop up and then go down a minute later. That's just extra wear on them. Can anyone help please?
Thanks
Thanks
Ungrounded Moderator
Canadian Firebirds came with automatic headlights. They can be easily added to a US model by just installing the light sensor available from the dealer for $20.
Disabling automatic headlights on a Firebird is exactly the same as on a Camaro - just connect the two sensor wires together so the system thinks it's daylight all the time.
Is there anyway to make it so you can turn them off, like by the switch? I wanna be able to make them turn off, but turn them to automatic when I want to? You know what I am saying?
Oh, and where is the light sensor?
You can add a switch to enable and disable the automatic headlights but you can't use the factory headlight switch to do it. After all, it's already in the off position when your headlights go on automatically. Instead of just connecting the two sensor wires together, connect them through a switch. When the switch is on, the automatic function is bypassed (manual mode only) and when the switch is off the automatic headlight function will work.
The sensor is located in the dash next to the red alarm LED beside the defroster vent.
Alright man. That will be easy to wire that. Thanks a lot!
Oh shoot, one more question, how do you get to the sensor? Can you take the vent out? Again, thanks for the help.
Copy & Paste Moderator
From the Lighting FAQ:
Auto Headlight Defeat
The light sensor for the feature is located near the alarm LED. Short together the two wires going to it. A Scotch Lock works well for this (3M calls it Scotchlok). That will make the system think its always daytime and never auto activate the headlights. If you want a less permanent defeat or want some control over when to defeat it, you can wire in a switch instead of just shorting them together.
Once you get the dash panel pried up, you'll see the sensor just like in the photo VIP1 posted above. The whole job can be done in 10 minutes after you've done it the first time and know where all the clips are. Allow about half an hour for the first time.
