Thanks Kee for the CDT mids!
The holes should line up damn close if not perfect. You'll see how the stock mount is shaped...that's the basic shape of them with a little added to the sides where there is nothing holding them to the door. This should give you a little extra material to work with so you can attach them to the door in that location. I don't predrill those holes so you can judge where you want to that for yourself. There are only 3 screws holding that in and this should give you enough material to add a forth.
