Street Racing & Kill Stories Basic Technical Questions & Advice
Cadillac CTS V
Old 02-10-2009, 12:06 AM
fatjet00's Avatar
Default Cadillac CTS V
Went to the drag strip the other day, had a blast. Saw 2 Cadillac CTS's there. The fastest one ran 12.40 @ 112. Has any one here ran any of them? I like the car, a good looking fast luxuary 4 door. Is it the ls6 or ls7 they put in these? I just haven't seen much talk about them on here.
Old 02-10-2009, 02:01 AM
ElkySS's Avatar
the 04s had LS6s and the later ones had LS2s
Old 02-10-2009, 07:43 AM
necrocannibal's Avatar
I think hes talking about a the new ones that have the LS9 in them.
Old 02-10-2009, 08:56 AM
DiscerningZ32's Avatar
The 09 CTS-V has the LSA, which is NOT the same as an LS9....
-The LSA has a 1.9L Eaton blower vs the LS9's 2.3L Eaton
-THe LSA produces 9 psi vs the LS9's 10.5 psi
-The titanium connecting rods and intake valves of the LS9 were replaced by forged powdered metal and SilChromel, respectively.
-The exhaust valves on the LSA are not sodium filled either. The exhaust manifolds are cast iron rather than stainless steel as on the LS9 and the main bearing caps are nodular iron rather than steel.
-The pistons in the LSA are hyper-eutectic cast aluminum rather than being forged.
Here's my source of info:http://www.autoblog.com/2008/01/14/d...-2l-superchar/
Old 02-10-2009, 11:38 AM
obZidian's Avatar
If it's a 04-05, it has a ls6 at about 400hp. The newer ones are @ 556hp.
Old 02-10-2009, 02:10 PM
ElkySS's Avatar
i think they may have changed the motor mid year in 05 i could have sworn iv seen a couple 05s with LS2s
Old 02-10-2009, 02:13 PM
obZidian's Avatar
Well, my 05 had a ls6... awesome motor.... **** rearend!
Old 02-10-2009, 02:48 PM
89rs400&335's Avatar
Re: CTS-V2
I would think they would dyno a little higher - https://ls1tech.com/forums/cadillac-...no-sheets.html
Seems that 450 is about the norm.
Old 02-10-2009, 03:15 PM
Kurlee Daddee's Avatar
04-05 CTS-V 400hp LS6
06-07 CTS-V 400hp LS2
09 CTS-V 556hp LSA
Old 02-10-2009, 03:41 PM
adanieljohnson1's Avatar
I thought the new V's are in the 11's?? I would think that the V that the OP is talking about would be a supercharged V???
Old 02-10-2009, 04:06 PM
Seems not to be the case - http://www.cadillacforums.com/forums...ing-1-4-a.html
Probably some gravity challenged drivers...
Old 02-10-2009, 08:43 PM
Deuuuce's Avatar
Potential for 11s. Not many will get the necessary 60ft, I'm sure.
Old 02-11-2009, 07:38 AM
Whoa settle down there bucky.
Old 02-11-2009, 08:42 AM
Actually, that wasn't directed at you, I didn't even see your post
I only wrote that because alot of people still think the LSA and LS9 are the same thing.
Figured I'd get some quick facts out there.
Old 02-11-2009, 08:50 AM
hahahha, +5
