fastest freemod times?
I've got a couple of buddies who both ran 12.90's from freemods alone. should I expect similar gains? Most stock Ls1's around here average 13.20's with descent drivers. Also I heard that 98's came with bigger injectors than 99 & up and that the t-56's are weaker in 98's. any truth to this?
STF veteran / 10 second club
I responded to your new post in the "New LS1 Enthus." section.
Originally Posted by xphantomws6x
98's do have the largest injectors yes ... and the T-56 is identical for all years as far as I know.
Freemods alone (without any weight reduction) will usually get you into the low low 13's or high 12's. I would say the skill of the driver is much more important then the 5-10 hp you may pick up from the free mods (especially in an M6).
