GT500, Fenix, 347 Fox, KFC, LSx Monte Carlo, Z06s, N20 T/A
#41
i see it as the fox took his car from a 15.xx car to an 11-12 sec car, and the Camaro went from what a 12 sec car stock to a lower 12 sec or high 11 sec car? Hence, i'm more impressed with the fox. Not sure why all the butt hurt. If everyone had ls's it would be pretty boring. Guess what....not everyone wants to run an ls motor in their car....i know its pretty difficult and hard to understand for most of you, sorry to hit you with that truth.
#42
Not quite If posting a response to correct ignorant ***** such as Exhibit A (below), then you got me pegged, dude!
I said 400 because, like every motor, there's mild to wild. A mild 347 should be making at least 400. Stopsign made 456 with a 331 (uh oh, that's less cubes than you and more power, AKA story of GM's life), keep posting and proving your ignorance about Ford anything. I would've thought after you were made an *** of the last 2...3...4 times you tried talking about Fords with some certainty, that you'd give it up for good.
Yes, little Dougie, you get your *** handed to you pretty much daily. Not always by the same person, but usually it's one poster within a list of 3 or 4. I feel ashamed for a few minutes after I do it but then that goes away when I see you post more about Ford vehicles you're clueless about
Another point made that my furd is nicer, cooler and faster than yours.....that one has to hurt.
It's not really a comparison. I'd take a 347 SBF with the right parts over any hacked up f-bomb with a 346 (that still uses aftermarket parts but the owner talks about it like it doesn't )
In typical General fashion, you need that cubes advantage to sleep at night. There, there.
03turbo bought a carbed 347 car. Race car really, cage, no heat, tube k, race brakes, stalled auto......blah blah blah. Now he he likes it and that is all that matters. But it's not as fast as my smaller engined car.
Come on now Hio, I think you would know what Pro Comp 190 SBF heads are. Out-of-the-box, 190cc runners and max flow around 220cfm. About equal-to or not even as good as stock 241/853 LS1 heads. As far as aftermarket SBF heads goes, they suck. For a light 5.0 stroker build with those Comp 190 heads, 352whp ain't too shabby. Not all built, stroked, aftermarket headed 5.0s are the same, like you like to come off acting like they are. What we have here seems to be a stroked 347ci 5.0 on par with a light bolt-on 346ci LS1. Looks like not a bad running convertible Fox for what it has and makes. Not sure why you can’t see things for what they are and always have to knock these Fords all the time.
It's guys like you who know that not all stroker builds are the same and don't over exaggerate all the time just to knock the "other" brand.
"What we have here seems to be a stroked 347ci 5.0 on par with a light bolt-on 346ci LS1" which is basically what I said that offended the furd crew. Except it's not "on par" face it. It was getting pulled and the camaro had a passenger. When they swapped the passenger it got pulled real good.
The reason that I said I was impressed, was because the build by the vague description given, seemed very mild. The starting point for the car was also worst case scenario, being a vert. Given those two glaring facts, my thought was that it ran well, seeing as KFC's ride is no slouch. I am sorry for sharing my opinion sir Hio.
#44
An "average" driver in a 5 speed fox vert would probably run a high 14 to low 15. Nothing offensive about it. Your derogatory response to EVERYTHING that isn't yours on the other hand...is.
#45
Not at all......what we have is a double standard towards me. Go get on r6's *** for saying the 347 ran with a mild bolt-on camaro. You guys got on my *** for saying the same thing. If say foxes run a 15 the ****** world comes to a end. Every furd swinger on here mopped up ls1's with a mild bolt-on fox then....lmao fact is most h/c foxes would be lucky to run with a mild bolt-on lt must less a ls car.
#47
When he's wrong, he brings my coupe into it. It sort of like his secret way of saying he taps out. He does it every time he has no response with any substance
HiO owns a car so he can claim he's unbiased lmfao. If that doesn't scream "I need professional help!" then I don't know what does.
#48
We did. Stock for stock they were good runs but never lost to one. I had a 305 in my monza....factory v8 car and dad had the iroc(still does).
I'm far more unbiased than you are for sure. I give the new 5.0's plenty of credit. You spend more time trying to discredit the gm stuff.
Your coupe is a perfect example of you yakkin about furd and then not running furd heads. Put your money where your mouth is. If the **** is that great then run it........if not then stroke it and stick some aftermarket heads on it. Seems to be the furd creed.
#49
1 Post
I have 0 faith in an LT1 with boltons... Thats Toyota Camry V6 territory.
#50
#51
If you were truly wanting to compliment the ls you would've said "Damn it took a 347 stroked, headed, cammed furd to run with that mild bolt-on ls....those things are stout. " But you didn't......you thought that fox ran good.
Now you have twisted what you said into a compliment for the ls.....lmao What a joke.
#52
You are special. We're all aware that KFC's car runs strong. Obviously the mustang was built...still with me? K. By saying the mustang did well to keep up with a bolt on LS...what does that say about the LS? Your comment was condescending, AKA, you being an *******. You did it to illicit the exact response that you got. Congrats, you win.
#55
We did. Stock for stock they were good runs but never lost to one. I had a 305 in my monza....factory v8 car and dad had the iroc(still does). I'm far more unbiased than you are for sure. I give the new 5.0's plenty of credit. You spend more time trying to discredit the gm stuff. Your coupe is a perfect example of you yakkin about furd and then not running furd heads. Put your money where your mouth is. If the **** is that great then run it........if not then stroke it and stick some aftermarket heads on it. Seems to be the furd creed.
The reason you piped up is because you know that's not a great example of a 347, but by playing stupid you're also able to act like it's the norm so you can put down a Ford yet again. Same old **** from you, different day. Your tactics aren't exactly rocket science
You hold onto that aftermarket **** when in reality it has no practical value at all. You spent more for your Fast than I would spend on AFR185 aluminum heads...probably a cam, also.
There are guys who spent less money on their f-body than you have (I'd be willing to bet but I would never know because there's a 0% chance you'd say how much cash you have in your car) and run 10s, and use the aftermarket. Let that sink in real deep.
Inb4mycarisntsetupfordragracingasidropaford9inchin therear. Lmfao.
#56
The heads on the stang are aftermarket and better than stock right? The heads on the camaro are stock.
#57
You've got to be illiterate. I pay compliments to the LS stuff all the time. It's the typical ignorant owners (aka you) that know next to nothing about Ford motors and continuously knock them. 347/331 motors have owners who put the wrong parts on them, more than any other motor I would say. The mindset of keeping tiny induction parts on those motors drives me nuts.
I have no idea how much money is in my car, I bought it new. So I'm sure someone could buy a $3000-5000 f car and go faster than me for less based on purchase price alone........your point was?????
If I wanted to run my times on a slick I'm sure 10's would not be a problem. But I don't want to. It's not a goal to keep track of what I spend on because I just tinker with it when I have time and usually buy used parts for it. What's it matter to you??
I also give you a example of 03turbo's 347. It went a 11.4 @118....it's in a race car fox with race brakes and a cage. I would consider it a decent example of a 347. It may have some left in it.....I would hope so cause the car probably weighs less than 2800lb.
It is what it is. Fact is if a built furd sbc was so awesome it should not have had a problem with a stock ls1. Most of these guys want to compare **** like that when the fox has a significant weight advantage. The fox no doubt has a weight advantage here to......just not 500+lb to make up for it's lack of motor like they usually do. And it shows.
#58
It's funny when you up the cubes of a Ferd motor how butt hurt everyone gets (well one person)
He'll argue about aftermarket parts yet his car is motor swapped and rittled with aftermarket ****.... If he was all about stock like he says he is he'd have an LS1 using all stock parts...... Everyone sees through your bullshit Doug, your car is fast but for obvious reasons
#59
What's dumb is when a 5.0 SBF has a 347ci kit and aftermarket heads that are equivalent to stock LS1 heads, some like to act like the Ford should blow an LS1 out of the water just because it's a stroker. Then act like the Ford is a complete disappointment when it doesn't just for an excuse to downgrade Ford. One that's built on the mild side and only makes 400-420 flywheel hp doesn't make it a big POS because it can run with bolt-on LS1's. It actually make complete sense, stock 5.0 SBF=215hp, stock LS1=345hp. Something has to be done to the Ford to catch up.
#60
You know what I'm talking about when I say this. MAJOR engine components. But yet you continue to run your stupid mouth.
No one is butt hurt about the upped cubes on the furd......it still got beat by the smaller stock engine.
