Cam/Stall G8 and H/C/I T/A VS Cammed C6 Vette
too many dig races , and the ta driver needs a tick master and mgw shifter. Dont miss those gears . And the vette driver seemed pretty good from a dig against the ta that is clearly set up for a dig .
It has a tick master already and i think a hurst shifter. But I haven't changed the fluid in a while. Waiting to install the monster stage 3. My tuner also recommended the TRZ anti-roll. My car has no bottom end power unfortunately. Installed a Vic. JR and accufab and left the same cam that was in it. Should be a beast on spray though.
Yeah he did a burnout every race and I started feeling bad for my clutch/tires so I stopped doing burnouts haha
Bro...strongly suggest changing that fluid. It's so easy. I've saved friends and customers thousands by them wanting to change a clutch setup....when it was just the fluid that was spent. The idea is keeping up with it maintenance wise. I would change your fluid every other weekend to every month if you daily it and drive it hard. I'm sure you know this..just saying. Change that ****. It's a vital part of longevity and quick shifts in any hydraulic setup.
Well, fluid gets hot, as in burnt. Moisture also. Goes from a clear fluid, to a black. If you constantly change the fluid, you'll avoid this happening. If you don't abuse it much,..your fluid will probably stay clear for a while but, if you drive the car hard....it will get dark in a short period of time. Every manual transmission hydraulic vehicle ford or gm I have had this happen. Do research on it...actually, here you go...
I suggest everyone with a manual go out and check your ****....
Btw Nice vid! Luv seeing the dig action. Nothing wrong with some low rolls, but you never see much dig racing sround here these days because 90% of everybody makes more power then they can put to the ground.
The TA was clearly the quicker car and the drivers reaction time was better. However after 3rd gear he was no longer pulling. My guess is from a roll it would be pretty even, from a dig TA owned.
Again Nice vids!! I do not normally post much here due to all arguing and **** talk that goes on but this one I had too.
