Ls1 vs 3v and coyote
You should get some ebay headers along with an ORY pipe, and swap in an m6 rear end with 3.42 gears and a 3600 stall. Then get it tuned. Those cheap mods would make a huge difference with drag radials. You would definitely spank that 5.br0.
Lol actually you guys advice is right in line with my vision, I believe my rmc is starting to leak so I was thinking of stalling it while I'm there , also lid, ls6 intake (I have one laying around), headers and exhaust also in a few months a small cam.
Just make sure you get a good transmission cooler for the stall. With those mods plus a cam, you should be able to run high 11s full weight. I'd go with a FAST intake though if I were you.
#33
TSP makes a decent set of longtube headers (1 7/8). They're $400 I think
#35
#37
Yeah until you get some good flowing heads and a decent sized cam to match with, you'll be fine with that ls6 intake.
Couldn't agree more.
Like whiplash said, get a good trans cooler, you'll need it and high 11's is not a problem for a stalled, cammed ls1 so your goals are right on spot.
#39
Unfortunately they went up in price lately, but most guys here run this one or the 70274. The 70266 works fine for mine and I do alot of in town driving with high 180's in mid summer, stop and go with a little beating on it. Highways stays low to mid 160's.
http://m.summitracing.com/parts/bmm-70266
If I don't beat on it then it stays in the mid 170's mid summer stop and go.
Edit: it's worth it though, because without one you'll burn your transmission up in no time because of the heat.
#40
Thanks guys, all the suggestions and help is greatly appreciated...I've been doing a ton of research to figure out what I'd need to get to my goal but having people who has been there and done it is priceless, also 85$ for a trans cooler and that's awesome will definitely pick one up , 200-400 for headers Is also great. Quick question though y or X pipe? And came size?
