Ls1 vs 3v and coyote
#61
#63
#65
I guess. The advancements in tuning & being able to use different fuels or cooling methods to keep a stock bottom end alive are absolutely phenomenal. I wouldn't be scared to push any LS motor to 550-600whp on stock bottom end as long as you got the fuel or cooling mods for it.
#66
plus if hes looking to spend less than $5k.... then turbo might not be the best idea. Kits ive found are usually upwards of $6k (unless you do all ebay shopping)
#67
Edit: my kit will be done for less than $1,200.
#70
#72
With just stall, full exhaust, your ls6 intake, tune, and drag radials it'll be a whole different car. And will hurt a lot of Butts on the street. Then you can keep doing little **** like TB, ram air, weight reduction. You don't even need a cam to run solid 11's.
#73
True story
#74
Call Brian tooley and tell him what you want done he will hook you up for your cam. Trans cooler that was mentioned is a definite must! I'd go x pipe and dumps imo. Also get a trunion upgrade. A truck MAF at your local junk yard. SLP lid is like $110.
#75
#76
#77
Good luck, 4th Gen is a great platform for a go fast build
#79
^^^ I like sleepers. We had a buddy with A4 Z28, small stall converter, stock snowflakes with M/T drags, bolt-ons and a quiet muffler. Surprised a lot of people
#80
Honestly I want it to be a looker, I don't want it to sound like a drag car or anything...to start with I'm going to stall it, gear it and do headers and intake and drs. Then after I tire of that I'll start looking at building it.
