LBO 17 SS vs FBO Cobra jet WR 5.0 ultimate build
#64
Lets see what happens this fall...
Not sure an auto with a stock stall is a huge advantage. Im leaving off idle lol.
With a stall id be 60 ft 1.4x
#65
Its not the best the car can do. It was 80f and the manifold was not fully tuned. It was the first time I ran it. I actually lost speed in the 1/8 because I was still on stock shift points.
Did you tune car for manifold swap? A/f etc?
#66
Car was tuned for a ported stocker. My last run at the track was maiden voyage so it was not retuned. Shift point were raised but car did not take them the first time. These things are a bitch to tune.
Tuner said last log we could take a bit of fuel out around 5000. But all in all it wasn't too bad as far as engine tune.
The trans was still only shifting at 61-200. Which the main advantage of the msd is the power after 6000 not dropping off as quickly. He thinks ill pick up another tenth now with it shifting at 6500. Then im gonna try 6700 and see if it likes it. Ill go up until the car slows down.
Tens in negative DA should be in the bag. It would be nice to do it in positive DA though
#67
Close race. 5.0 ultimate build barely enough for an LBO 6g
17 SS CAI, headers, E85, rear welds
S550 CAI, headers, cat back, cobra jet manifold, E85, aluminum DS, interior seats removed
Looks like both are m6
https://m.youtube.com/watch?v=KfCYkkzee94
#68
Originally Posted by HioSSilver
All you had to say was "yea he whopped my bolt on cars ***"
But like every other furd ****** you couldn't get it done with out boost.
Guess when you don't know what you're doing, doesn't matter which platform you own
#71
Troof....take a blower swap for all but 13/14 gt 100 to keep up with a 6gen.
Same ole' same ole' outta you.
So you think my bolt on ls6 would go alot faster in someone else's hands?
Yup...i think it has 10s in it. I think the term is 10s capable these days.
Yea more boost i agree. That's usually the sort of effort a furd requires isn't it.
It runs good.....real good. Ported blower helped it alot up top. Metco crank pulley set up nocked alot of rotating weight off the crank to. Deck honing the cylinders straightened them up nicely.
What were you saying about effort again?
