LT1 supra vs SRT4
Very nice, Dirty Mike. As stated above, how many Supra's do you see that are LT1 swapped.
I like it and good run! I can also appreciate how financially conscious you were on this car. Nice job, man.
All the Lt1 hate is hilarious....
Do what you want, if you don't like it after a while change it. If it isn't gast enough move on to an Ls platform.
I personally would not use that cam it is a good grind but thete are much newer grinds that provide a better power curve.
Torkhead has the conversion to convert to the Ls pcm which makes an Lt1 wake up more.
#33
Don't knock the B body motor. The cam was designed for a lot of low end grunt to get it's big *** moving. It would be fun in a lightweight car.
This.
This.
