OJ vs 17' ZL1
#241
I agree there's nothing wrong calling it a big bore LS3, but I'm also accepting enough to know there's nothing wrong calling it a destroked LS7 with LS3 style heads. You should realize though you were the one originally freaking out over it, belittling and calling people names over such stupid ****. You're a smart guy, it should be easy to realize. Yeah, looks like I understand plenty. If you're childish mentality wouldn't get in the way, you'd notice that too.
#243
I call people names because they act like morons. It's not my stupid ****.....it's theirs.
For it to be a ls7 it has to use ls7 heads......even for to be a destroked ls7. That's just how it works with no bullshit involved. So therefore it is wrong to call it a destroked ls7.
Fact is the morons want to call it a ls7 because it makes them feel better about no coyote ever making the power hammer did. So there's no way a ls3 could do it. Oh wait.....ls3 vs 5br0 challange. It happened there to with a full ls3.
Best advice i can give you is don't buy into their idiocy.
#244
Really can't understand why you such an idiot hiho.
So a guy with an ls7 puts trick flow heads on his motor it's a trick flow now?? You really are stoopid.
I also did come up with a question:
Your car with "stock" bolt on ls6 runs around a 10.9@130mph. Hamms car with a big piston, short stroke, solid roller cam, mid runner fast intake, aftermarket ls3 heads, spinning between 7500-8000rpm, making 200+ more rwhp, only a few tenths quicker & not even 140mph?
#245
Mm with a head shot on snake.
Be alot of effort. And 10k rpm for 700hp is ****.
Not that hard. I tried to get nathan to put a 5br0 in the fox.
Not according to the slip you posted. So now ypu admit you needed even more mods.
You seemingly keep ignoring that he had a shift to recover from at a bad spot on the back half. The fact that he was less than 1mph off your best but .29 slower et shows it was making up time via mph by the end of the track. End of story.
My furd is faster than yours
It woulda drive around you and marc in its previous state when someone else owned it.
No effort? The camaro wasn't rebuilt with good pistons. Camaro frame wasn't tied. Camaro not running any additional atmosphere. Camaro don't have a tube front suspension. Camaro has oe style brakes....notch brakes are upgraded to sn95.
Camaro has the oe harness and trans that came in it.....the notch don't. Notch has hydroboost brakes.....camaro stick stuff. Notch gonna have it's work cut out for it to keep up with the camaro when the camaro was still on a 10bolt.
What were you saying again?
I've posted weight pics and dyno graph. That puts the lying on you.
Btw.....how much power do you think a bolt on ls6 is capable of making?
Only you would be dumb enough to put ls1 heads on a 6.0.
But essentially a 6.0 is a larger ls1. They even use the same cam. Maybe you should research before you open your ***********.
The dumbest **** is trying to say it's something it's not. Actually saying what it is does not constitute a argument.
A 4.8 used the same cam as a ls1 to. Maybe some of why yours and nates **** run like **** or not at all. Neither of you have a clue to what you have. Both of you are like antifa......don't know what you have so you destroy it.
Now.....do you dumb ***** know what it takes for a engine to be considered a ls7?
Hint.....it's not bore diameter
Glad i could straighten this mess out.
#246
#247
LMAO!!!! Kind of pathetic that Spermy doesn't post his own time slips when he went slower but rides Pops coat tails for his slip
7.2@98mph was my last h/c pass before I went turbo. Mild build with stock heads, intake and tb in bad DA and it hangs with a bolt-on bro that's on a fast list?
#248
Probably because it was his first time to the track with it. The track went to **** enough they stopped running. No doubt his car has 9s in it @140+ once sorted. But if you weren't suck a ******* moron you would understand that.
Hio, can you call GM and tell them that they stamped my two blocks wrong then? I mean ****, if my 4.8 is now a 5.7l LS1 because it will have 241 heads on it then let them know they stamped it wrong with 4.8/5.3 please. Also let them know that my LQ4 6.0 is stamped wrong as well and they made it out of the wrong material, iron. Thanks!
So what you're essentially calling Hammer a liar then, eh? Well I mean he did try to lie to that magazine editor who did an article on his build and published it. But then later told the editor the truth and it was edited for accuracy, even the article stated it as an destroked LS7.
How bout this. Ask hammer what it is. Not that he hasn't said.
It's not my fault you're to much of a idiot to grasp it.
#249
Last i checked trickflow had a heads for cathedral, ls3 and ls7 stuff.......duh. your* such a idiot
Does anything you say ever make sense?
Hammer told the guy what it was. The editor that wrote it adlibed a little.
So now you're calling Hambone a liar too? Because he did give the editor/writer a call back to correct him that it is actually a destroked LS7 with LS3 style heads because of the guilt from trying to lie on a widely read magazine the first time.
#250
Every ******* post of Cyber's is crying "mild this mild that" well according to your role models, H/C is H/C, so congrats on getting out ET'd by a bolt on br0 in your engine swap HC build.
#251
The other hilarious thing is Hio, when talking about hammer's car, it's easily got another half second and 10mph hidden in it, but any Mustang runs and that's the best it could ever do, ever
Stay away from the paint fumes for a day, angry elf.
#252
#253
#255
Your slip says 200 DA, what do you think it would have run at my local track of 2500-3500 DA?
Funny thing is that I post my slips regardless of only getting one pass(no roll bar) in less than ideal DA. Unlike team insecurities
#256
It's not my fault you're too much of a one sided **** gobbling hypocrite to realize it's a destroked LS7.
A ls7 has to use ls7 heads dumbass. If a ls7 block has a ls3 crank and ls3 heads it is essentially a big bore ls3. How could Jesus christ make a human this ******* dumb.
It's not even a lie from you anymore. It's just that you're that ******* stupid.
Class is dismissed
Thoroughly cementing his cars hero run status. Now that he has a vent tho he will learn what actual power is and no doubt won't be affected so much by changes in weather. Those 5br0s are finiky.
#257
Originally Posted by HioSSilver
You make 0 sense. You don't even know wtf you're saying.
It's not even a lie from you anymore. It's just that you're that ******* stupid.I didn't say 1sec and 10mph. But yea.....when he goes over 1sec faster than you did and up 20mph over what you did but with a worse 60' than you had. It's pretty ****** easy to see the potential he has there dumbass.
Class is dismissedPoppa went like 11.8 11.9 in that da.
#258
7 Second Club
So we can all agree that it's a LS73 hybrid 388 that need race gas to touch a 10. Neato!
