Ford needs a supercharger to compeet
#44
I went like 130.6 last time out with a best of 141 on a previous time. Now if your gonna use your best mph them ima use my best. If you're gonna use your best et mph then ima use my best et mph.......either way your math is fucked here dumbass.
**** i would take that 500lb and only 15lb of boost and would still drag your ***.
So it seems you are whining about your junky 5.4.
Hell pulley your bigger blower to oe atmosphere like me and that will net you a dragging to.
For his "car" to weigh the same his "car" would have to be lighter because his engine/blower stuff weighs about 400lb more than my engine.
So technically his "car" is only about 100lb heavier than mine.
Are you telling me that you think a iron block aftermarket blower car should weigh the same as a bolt on na car? That's like full retard.
It would hold 15 fine. And that's all i woukd nedd to drag his ***. Yours has it's hands full as it sets. This proving yes you even ******* need a aftermarket blower to keep up.
Lolz
Lolz
Put a blower on it. I have already ran and beat a light ls6 car with a blower.
#45
Seems as tho you needed 2 power adders to get that done......it's a shame really. To think that you think furd is that much better but yet you're dumb enough to not realize the only thing you do is out power add someone else.
Btw....that's not my car
So lets get this straight.....your furd sucks so much you had to spray the guy even with his shitty driving to run with him......
Plus you needed race gas. Your junk is worse than i thought.
#47
7 Second Club
That full sausage C5Z got walked.
Good run!
Good run!
#49
Yea you car is way slower.
Let's get this straight the ls6 sucks so bad that my SLB 4v came around his moon boosted C5Z.
#54
Downplaying mods. How? My car with a YSI and cams would have made another 100+. His car with my combo would have made about 100 less. It's common sense nobody is down playing combos.
#55
#59
Car was slower with the Gen 1/kit then it was with Gen2 combo. Out power adder? That car had a YSI on ~20lbs, cam, and meth. I had not a single advantage in that race other than 4v power and gears.
The ls6 sucks so bad ypu couldn't out run it with your na 4.suck nor could you get it done with your oe blower.
You should really be glad and thank me for not being boosted. I would **** your furd god in his *** then.
Troof.....a extra power adder and rg to go with it but no advantage
#60
WTF are you talking about? The car made about 793std with the Gen1/kit combo. It made 805std with the Gen 2 with no kit.
Lol....nice try but no
